by DI7
my phone is connected to 4G but facebook, messenger and Instagram won't load
by Profile closed
Not applicable
Solution
Re: my phone is connected to 4G but facebook, messenger and Instagram won't load
Hi @DI7
Go to your online EE account and try switching your Content lock to STRICT, reboot your device, and then switching your content lock OFF !
You might need to try this a couple of times!!
This should fix your issues.
Thanks 👍
BustaCrabb
by Profile closed
Not applicable
Solution
Hi @DI7
Thanks 👍
BustaCrabb
by DI7
I've tried a few times and it still doesn't work, any other options thanks
by Profile closed
Not applicable
Hi @DI7
Sorry!
It didn't work😞
You could try DEACTIVATING the content lock and see if that helps ?
Other than that I have no further solutions!
So you may need to call EE CS and let them look into it for you!👍
BustaCrabb
by DI7
Its worked!!!!!!!!! Thanks so much BustaCrabb 😀
by Profile closed
Not applicable
Hi @DI7
Wow! 🤗
What did you do ?
That's great news!
Cheers 👍
BustaCrabb
