by MattyG099
my data is not working for snapchat however it is working for everything else
My mobile data is not working on snapchat and i have checked that data is turned on for the app and i have deleted it and re-downloaded it however it is still coming up with 'could not refresh'. My data is still working for everything else such as instagram and whatsapp.
Solution
Re: my data is not working for snapchat however it is working for everything els
Hello there @MattyG099
Welcome to the community.
Can you try a network reset on the iPhone.
To do this go to Settings > General > Reset > Reset Network Settings.
This will remove any saved WiFi passwords to complete the reset.
Let me know how you get on 🙂
9 REPLIES 9
Hi @MattyG099
Do you have an IPhone? If so make sure mobile data is active on the app under the app settings.
by MattyG099
Yes I have an iphone. Under the app it says that mabile data is active
Solution
by Azaleemwilliams
New Member
I performed the network reset. I made sure snapchat is completely up to date as well as my iphone. My data works in every other app except this one. How do I fix this?
Morning @Azaleemwilliams
If you go into your Settings on your iPhone then scroll down to Snapchat, is mobile data turned on?
Thanks, Leanne.
by megangrace11 Investigator
Did you solve this problem because mine isn’t working either?
Good Morning @megangrace11
Have you checked data is switched on for Snapchat?
How long has this been happening for you?
Do you have a problem with any other app?
Speak soon, Katie 🙂
by Mkhaiya
New Member
I’ve also got an I phone xr and my data on snapchat doesn’t work
I’ve tried to rest my network and my data is on under snapchat
how can I fix this ?
Hi @Mkhaiya
Welcome to the community. 🙂
Could you try changing the parental controls in your My EE account?
Just go to Menu > Manage Device > Usage Controls > Full Access.
