by Dan19 Investigator
mobile data
Hello my name is Dan and i want to report a problem with the 4G mobile data . So i would turn on my data and it would say 4G on the top left on my Iphone 7 but if i go on any social media it would say no connection and if i go on safari/google chrome it would say no internet connection . I would reset my network setting , take out the sim card and the mobile data would still not work . My Mobile data Current period says 1.5 MB and current period roaming 0 bytes , i would also put my mobile data on roaming on is this the problem . I NEED HELP
10 REPLIES 10
Re: mobile data
If you're in the UK, you're not roaming.
1.5 MB is not much to play with. You'd soon use it up at most sites.
Re: mobile data
So what should i do . So do you think i should enable roaming on , on the mobile data options . For some of my apps I made the green toggle to a gray one . I need help
Re: mobile data
No, that's my point. You are not roaming, so activating it is pointless.
Re: mobile data
Then what should I do
Re: mobile data
Can I hve instructions then
Re: mobile data
Sorry, I've no idea on your problem. Just pointing out that roaming is irrelevant when you are in UK.
Re: mobile data
So should enable roaming on or off on the mobile data option on the iPhone
Re: mobile data
So i would turn on my data and it would say 4G on the top left on my Iphone 7 but if i go on any social media it would say no connection and if i go on safari/google chrome it would say no internet connection . I would reset my network setting , take out the sim card and the mobile data would still not work . My Mobile data Current period says 1.5 MB and current period roaming 0 bytes , i would also put my mobile data on roaming on  this the problem . Can you send instructions
Re: mobile data
@Dan19  All toggles should be geeen to use mobile data.   You don’t need to toggle on data roaming when in the UK.
In settings>mobile data>mobile data options>enable 4G>Select VOICE AND DATA.
EE Employee
Re: mobile data
Hi @Dan19 and welcome to the community.
Has the information given above helped with your issue?
If you are still having issues you would need to speak to our technical team.
Many thanks,
Lee
Recent solutions
