by brianmorgz Investigator
mobile data not working
Have found that my mobile data faciltiy is not working. Recently changed my contract and now unable to use mobile data through Google, facebook etc....
Have checked settings and they seem all ok . Any suggestions ?
Solution
Re: mobile data not working
Thanks for the response. Finally conceded to factory reset. (all backed up)
. Works ok now
@brianmorgz  Have you tried restarting the device?
by Profile closed
Not applicable
Hello @brianmorgz sorry to hear you are unable to use data service on your phone. What phone do you have? Are you able to access this link:
http://add-on.ee.co.uk
If you are unable to use that link your phone is not connecting to the EE network. If you have an iPhone try tapping settings>general>reset>reset network settings (you will have to re-enter WiFi passwords) or for other phones here is a link containing the EE APN settings for you to confirm. :):
https://community.ee.co.uk/t5/4G-and-mobile-data/EE-APN-settings-Where-to-find-them/td-p/132083
Solution
. Works ok now
Resorted to factory reset. All ok now . Many thanks
by Profile closed
Not applicable
Hello @brianmorgz good to hear your data services are running as normal again now, thank you for coming back to let us know. Come back to the community anytime if there is anything else you would like to discuss/share. 🙂
