by Deb81
messenger will not load on 4G EE
For almost a week mine and my husbands phones will not load messenger over 4G. We had not changed any settings or passwords and it works fine on WiFi.
We have I phones.
I have checked that I have no restrictions on websites and done a factory reset on my phone but no joy.
by Profile closed
Not applicable
Solution
Re: messenger will not load on 4G EE
Hi @Deb81
Your issue might be in relation to your content lock!
Can you go to your online EE account and switch your content lock to STRICT and back OFF again, please! This should fix any or all the issues.
Let me know if this works please!!
Cheers 👍
BustaCrabb 🦀
by Profile closed
Not applicable
Solution
Hi @Deb81
Cheers 👍
BustaCrabb 🦀
Hi @Deb81
Did you port your numbers over to EE?
by Deb81
Thank you. That seems to have worked. Fingers crossed it stays that way. Thanks for your help and prompt reply.
by Profile closed
Not applicable
Hi @Deb81
Are you now able to use everything plus messenger ?
If yes? Then that's brilliant 🤗
Happy days 🌞
Cheers 👍
BustaCrabb
