by mdagli1
lumia 650 dual sim data not working
Just recieved it from Amazon. WiFi works fine but the mobile data connection is unstable. The top bar shows data being transmitted but browser and other apps don't work. Phoned EE to refresh connection but still not working. Didn't have this problem with my 640. Please help
Solution
Re: lumia 650 dual sim data not working
@mdagli1.  Is it not working or is it unstable ?  As you have said both.
 Have you put the correct APN settings in to the device ?
Have you tried putting the sim card in the other sim position ?
Solution
by mdagli1
yes! That fixed it!
never needed to enter the APN & MMS settings before...
thanks
Are you on EE, Tmobile or Orange?
Are you trying to connect to 4g or 3g?
Great news @mdgali1.
Glad that has fixed it for you 🙂
Have a great day.
Recent solutions
