by Jynx
just recently my htc 10 will not connect to EE mobile data
recently my htc 10 will not connect to my data it just constantly says disconnected and when i connect to home wifi and try to ooen the my ee app it just says there was a problem on there end i havent been able to use my data for awhile now ive tried everything
by Ace Contributor
Re: just recently my htc 10 will not connect to EE mobile data
HI,
@Jynx
http://setup-ee.wdsglobal.com/internet
Click on above link find your phone manufacturer and model send settings on your phone and install them.
Hopefully it will work for you.
Hi @Jynx,
Thanks for joining the EE Community. Smiley Happy
Are you only having this issue in one location or everywhere?
Is mobile data turned on in your settings?
Are you using a pay as you go or pay monthly plan?
Recent solutions
