by redsimon1969
New Member
is mobile data supported for a umi plus e helio p20 mt6757
hi,m thinking of buying the umi plus e helio p20 phone,but am concerned that mobile data will not be supported for this phone.i am a payg customer on orange atm.thanks
Solution
Re: is mobile data supported for a umi plus e helio p20 mt6757
If it runs on bands detailed here then yes.
Although Orange isn't 4G so ignore the 4G frequency. You would be better off upgrading your PAYG sim to EE to benefit from the additional speed, network and benefits.
Solution
