by Monkey3 Investigator
iPhone 7 Plus data not working with 3G
My phone connects to dara with 4g and is fine with WiFi, when try to use safari on a 3G connection I get a message about data not being turned on. Data is on and done all the normal fixes but no avail
any help please
Re: iPhone 7 Plus data not working with 3G
Hi @Monkey3
Welcome to the community.
Are there any maintenance works in your area? You can check on our network status checker.
Many thanks for the reply I have just checked there are no issues in my area I still have the problem ☹️
Thanks for checking, @Monkey3
Could you try resetting your network settings please?:
Tap Settings > General > Reset > Reset Network Settings > Follow prompts.
You may need  to set up your WiFi connections again after this.
Recent solutions
