by mrastoney
i need 12gb of data for 5 weeks, whats the best deal on a sim only?
i will be in england for 5 weeks, i need about 12gb, 4g....whats the best plan out there? and how much will this cost? thanks in advance 🙂
Re: i need 12gb of data for 5 weeks, whats the best deal on a sim only?
@mrastoney  Your only option is PAYG. And if you only want data you could just purchase a data only SIM card. Look HERE but these are restricted to a set amount of data each month.  Or look at THIS for payg and these give calls/text and data.   You’ll not get exactly what you want you have to compromise
EE Employee
Hi @mrastoney and welcome to the community.
Hope you find the information helpful.
Many thanks,
Lee
by noCGN Established Contributor
Please check before you buy that EE 4G network will work for what you need it for.
By look of things, FTP speed on 4G is restricted, only APN: everywhere works in their 4G network and its IPv6 only, so services like OpenVPN (2.3.X) does not work on EE's network.
There is probably more, so check before you buy to avoid disappointment.
