by ashtheawesome
New Member
how to block reminders to get more data on my samsung s7
EE keep sending reminders that data has run out and would like to block my samsung s7 so cannot purchase any more how do i do this
Re: how to block reminders to get more data on my samsung s7
Not sure what your question is. If you want to stop text then block them locally on your phone.
by Brilliant Contributor
Hello @ashtheawesome,
Welcome to the community,
EE remind you that you will have to purchase more data, to use data before it runs out, so you should still be able to purchase more data. Receiving text should be free, so not sure what your problem is.
If EE did not remind you and you ran out, then you would not be happy. They will only block you from using data if you have no credit and until you add credit, your phone will otherwise not be blocked.
Hi @ashtheawesome
Thank you for coming to community 🙂
Has your question been answered?
Cheers
Richard
