by chris225 Investigator
how have I used all my data when I been asleep and phone was off and charging
by Ace Contributor
Re: how have I used all my data when I been asleep and phone was off and chargi
HI @chris225@Have you received a text you use your all data?
Please check with this http://add-on.ee.co.uk link via your mobile data (not on WiFi ) where you can see your correco data amount.
yes, received one saying 80% used, then another one saying 100% used, even though i was asleep
by Ace Contributor
HI @chris225
Sometime you get wrong system generated messege.
You can always check your correct amount of data via this link http://add-on.ee.co.uk
says nothing left
Hi @chris225,
Welcome to the EE Community.
Your phone must have reached the end of your data allowance before it was turned off.
You can check which apps have used data in your phones settings.
To purchase a data add-on please visit add-on.ee.co.uk.
