by welsh2710
New Member
how do i turn my voicemail back on
How do i turn my voicemail back on? Thanks
Re: how do i turn my voicemail back on
@welsh2710  Hi,  you can do this by texting VM ON to 150.  If this doesn’t work you can text VOICEMAIL DIVERT ON to 150.
