by 4ner Established Contributor
how do i share data on my 2 accounts
On my account I have 4 sims, but they are in 2 seperate accounts. Is it possible to gift data between numbers on these accounts as i cannot find any option to do so.
Solution
Re: how do i share data on my 2 accounts
@4ner. You can only gift data to devices that are on the same account.
Solution
Is it possible to add all the devices into one account.
@4ner  You will need to call customer services for that as it should be possible as they are after all your accounts.
