by humphreykevin
how do I boost 4g signal when get 3g and 4g now and then ? 4g okay 100 metres aw
Hi
We have 4G now and then at home, with 3G also not perfect.
However 100 metres away I get full on 4G.
HOW do I legally boost the signal? as want to use 4G broadband as BT broadband is really slow.
Cheers
Kevin
by Prodigious Contributor
Solution
Re: how do I boost 4g signal when get 3g and 4g now and then ? 4g okay 100 metre
@humphreykevin
The following items work very well for me in precisely the circumstances you describe, although I think I'm further away from a usable 4G signal that you. I get c. 50Mbps down and 25Mbps up when the mast is working properly. Sadly, the mast near to me is pretty flaky, but this is a network issue and not down to the hardware.
http://amzn.eu/gdb0up0
Plus
http://amzn.eu/7bXtCxx
Plus
EE data SIM
by Profile closed
Not applicable
You cannot boost the signal in any way sorry.  All you could possibly do is buy an external aerial if your device / router / modem has an external aerial socket.
by humphreykevin
Hi Thanks for the reply:
I've not purchased anything yet from EE, so the question is do EE sell a router / device and aerial that I could try out. As just checking and if we stand at end of garden - 30 foot from house the 4G is good. So doesn't need aerial to be too far out from house. Where can I buy the router and aerial - as not seen on EE site 🙂 Thanks Kevin  p.s. on google search I found devices that do boost the 4G ( or say they do - are they legal or really of use !? - prefer idea of aerial ). Thanks Kev
Solution
@humphreykevin
Plus
Plus
EE data SIM
Recent solutions
