by MyungjaeLee
New Member
galaxy s8+ 4g doesn't work
I have bought my Galaxy s8+ in South Korea and using it with a ee sim card these days, but it doesn't provide me an 4g network. Is this because I bought it in South Korea?? need an urgent support here!
Re: galaxy s8+ 4g doesn't work
The answer is probably yes. SK use different network bands and are fitted with different radios/chips.
Can you go into network settings and try to connect manually. Also make sure you have lte/4G selected.
by Star Contributor
Star Contributor
Networks in South Korea use UK 4G bands: 1, 3, 7 and the S8+ does therefore support UK bands that EE use.
