by pauljb1 Investigator
ee settings for d link 4g router
Not sure what location to have this topic.
I recently purchased a D-link DWR-118 router in order to combine my ADSL and 4G connection. The router takes a ZTE MF823 4G dongle to provide the 4G. The dongle when connected to my mac works perfectly with all settings on auto. Once I connect it to my router it will not connect to the EE network. Under profiles there is nothing for ee just the old T mobile and orange as well as the other networks such as o2, vodafone and three. If have tried a few manual settings but nothing has work. Can anyone advise if I can use my ee data sim in a router like this (Do I have to active the sim for use in this device). Or anyone provide me with help on the particular setttings required to get this sim to connect.
Paul
10 REPLIES 10
EE Community Team
Re: ee settings for d link 4g router
Hi @pauljb1,
Welcome to the community 🙂
As long as the sim card is active, it will connect to the network.
Have you spoken to our home broadband team to check that your account settings and the device you are using it in are compatible?
Alex
Hi @Alex_S
no I haven’t. Do I contact them online? I couldn’t see where to contact EE about such a query. Can you point me in the right direction?
Use the landline nos. in my sig.
by Profile closed
Not applicable
If you can create a new profile, details of EE’s APN Settings can be found here.
EE Community Team
Hi @pauljb1,
If you are using an EE Mobile, you can call 150. If not, you can call 0800 079 8586 from any other mobile or landline 🙂
Please come back and let me know how you get on
Alex
Hi
I have tried all the EE APN settings to no avail.
It does ask for other things such as dialed number, pin and DNS primary and secondary.
https://www.manualslib.com/manual/977114/D-Link-Dwr-118.html?page=19#manual
See the setup here.
Hi All,
Just wanting to come back to you. Thanks for the support so far. I have managed to progress a little. I have now got the usb dongle working. However my questions relate to the settings.
If I set it in auto mode it does pick up ee signal but the APN settings default to t-mobile. Also I notice it uses IPv4.
I can manually force it to use EE APN with everywhere and can set it in either IPv4 or IPv6 (You cant have it doing both at once for some reason).
Can you advise if it is ok to leave in auto and use t-mobile settings? Will it make a difference to the speed or anything else? Or should I force it to EE? ALso what is better IPv4 or 6?
THanks
Paul
Hi there @pauljb1
The SIM card you have is this T-Mobile or EE?
T-Mobile will not pick up 4G where as an EE SIM card in a 4G area will connect to 4G.
Thanks, Leanne.
Hi @Leanne_T.
The sim card is an EE simcard.
It does appear to connect to EE 4g with t-mobile APN settings. In fact the usb modem when set to auto, automatically detects and uses these things. I have to mannually force it to use the EE APN settings.
Are you saying the service will be limited if I leave it on auto where it works under t-mobile settings and that I should force it to ee settings?
Hi there @pauljb1
If it is working ok for you on auto then it shouldn't need changed.
