by Maero
e-sim Data
Hello Since I’ve switched to the e-sim my data has slowed down remarkably. The data service is just intermittent and stops most of the time. I only have the e-sim and no physical sim at the moment. Any ideas? Thanks.
by Profile closed
Not applicable
Re: e-sim Data
Try a network reset.
by Maero
Re: e-sim Data
How do you do that?
by Profile closed
Not applicable
Re: e-sim Data
Settings>General>Reset>Reset Network Settings.  Follow the prompts until your iPhone automatically reboots.
You will need to re-enter any previously saved WiFi passwords though after doing this, however, no other data will be lost.
Re: e-sim Data
Hi @Maero
Welcome to the community. 🙂
Did @Profile closed's advice help?
It may be worth checking the network status in your area too.
