by Ashfield52
New Member
data
Which uses the most dat, mobile or roaming?
by Star Contributor
Star Contributor
Re: data
Hello and welcome to the community.
Your data use is determined by how you use your device, not whether you are in the UK or abroad.
Re: data
Hi @Ashfield52
Welcome to the community. 🙂
Could you let us know a little more about what your query is?
Re: data
When you are roaming you are still using mobile data, just as you would in UK. So, it'll be the same.
