Highlighted
data sim
I have a data sim in a mifi device. Ive not used it for a while but now when i try and use it just takes me to the mifi  router page and not EE top up page. It says its not connected but still says EE.
I topped up using the mobile number of the sim and EE  has taken my money but still not working.
Im worried its been deactivated ? Have I lost my money?
I tried to call EE but in hold fo 30 mins so gave up.
Highlighted
Solution
Re: data sim
Good Morning @domshirt
Thanks for coming to the community :).
I can see you have been provided some great advise so far.
You should now have a private message from myself for further details.
Speak soon,
Katie 🙂
Highlighted
by Ace Contributor
Re: data sim
Hi @domshirt
how long is it since you’ve used the sim?
Also, if phone lines are busy, the online chat feature can sometimes prove a little easier to get through to somebody .
Highlighted
Re: data sim
Probably about 9 months . It won’t let me register it on My EE
Highlighted
by Ace Contributor
Re: data sim
@domshirt
Ahh, if I remember correctly, it’s deactivated after 6 months but you get another 3 months to call EE to re activate it.   I’d definitely stay on the line to speak with them to see if they can do this, but if not I’m sure they can sort any refund for top up you’ve made.
Highlighted
Re: data sim
Then there's a good chance you've lost it & any credit completely. EE PAYG SIMs are deactivated after 6 months of non-chargeable use. You then have a further 3 months to call EE to reactivate it before it is lost completely.
Highlighted
Solution
Re: data sim
Speak soon,
Katie 🙂
