by okenemem Investigator
cant connect to internet on nokia 225
recently bought a nokia dual sim 225 and ive cant connect to the internet. i have a pay as you go sim with over 3gb data left , ive tried to google the settings tried everythiing please help
10 REPLIES 10
by Ace Contributor
Re: cant connect to internet on nokia 225
Hi @okenemem,
Please try this
Mobile data is set by doing the following:
  • Menu > Settings > Connectivity > Dual SIM
  • Select Mobile Data Connection and switch to ON then select Mobile Data and the Preferred SIM
I hope it will help.
@okenemem  Have you tried the sim in the other SIM card slot ?
this path doesnt exsist
there is menu > settings > connections and no dual sim settings there,
to make things easier i only had one sim when i was tryin to connect.
my issue is i go to the type in the settings i found online and they have different option boxes
e.g
access point, username, password, gateway, port, auth type, set homepage,
then there is advanced settings with the following
dns address, network type.
the data information i find online is
  • Name: EE Internet
  • APN: everywhere
  • Username: eesecure
  • Password: secure
  • MMSC: http://mms/
  • MMS Proxy: 149.254.201.135
  • MMS Port: 8080
  • Authentication Type: PAP
as you can see there are a few different fields
by Ace Contributor
Hi @okenemem
Find relevant phone to send Internet settings.
my phone is not on the list , does that mean that my phone is not supported
@okenemem  Where did you get the device from and what bandwidth does your device support.  Not all devices will work on all bandwidths as the device you have might not even be a UK spec device.
EE Employee
Hi @okenemem and welcome to the community.
have you tried the SIM card in an alternative slot.
Many thanks,
Lee
How would i know the band with support
i bought the phone from ebay
@okenemem  That device supports only 2G and EE only supports the 1800 bandwidth.  It will be slow when connected to the net.
Technology GSM
2G bands GSM 900 / 1800
GPRS Up to 85.6 kbps
EDGE Up to 236.8 kbps
have a look at THIS as this is all the APN setting that could possibly work in that device.
You’ll probably need to test the SIM card in both SIM card slots for this.
EE Employee
Hi @okenemem
Chris_B is indeed correct in what he has mentioned in regards to the bandwidth of the device 🙂
Many thanks,
Lee
