by kbr Investigator
can I use my phone in Australia
can I use my phone in Australia on the same plan
by Brilliant Contributor
Solution
Re: can I use my phone in Australia
@kbr, You can use your phone in Australia, but it depends what plan you are on. If you have the Max plan that came out in May and not the one before May, then your minutes text and data, put to 15GB, can be used the same as if you are in the UK for making calls and text in the countries that are included. In your plan. You need to make sure that roaming is enabled before going abroad.
If you want to use an Australian SIM card, then you need to make sure that your phone is unlocked.
You can find everything about roaming, by clicking on help and roaming charges.
Solution
EE Employee
Hi @kbr and welcome to the community,
Hope the information that @Schockwave has provided you with is of great use.
Many thanks,
Lee
Recent solutions
