by bpc-gary
New Member
are masts lte 1800 or lte 2600
are masts 10023 - Whitehead and 10024 - Kane Farm lte 1800 or lte 2600
by Scholarly Contributor
Solution
Re: are masts lte 1800 or lte 2600
Hi @bpc-gary
EE 10023 Whitehead is 1800mhz Band 3 4G
EE 10024 Kane Farm is also 1800mhz Band 3 4G
No 800mhz Band 20 4G on either mast.
You'll only find 2600mhz Band 7 4G in populated areas as it's used for a capacity boost and isn't as good as travelling and building penetration as Band 3.
I hope this helps.
Solution
Hi @bpc-gary
I hope this helps.
EE Employee
Hi @bpc-gary and welcome to the community.
Hope you find brilliant information that has been posted by @sully1311 to be of great help.
Many thanks,
Lee
