by jackwaight98 Contributor
apn settings
Hello. I bought a new phone SAMSUNG S6 EDGE on EE and really struggling to sort out the internet settings. I type in everything i need to in the internet settings menu but its still not connecting. I put the sim into another phone and it still does the same so it's nothing to do with the phone. Can anyone help me? Thanks.
14 REPLIES 14
by Ace Contributor
Re: apn settings
HI,
@jackwaight98
Please open this link.
http://setup-ee.wdsglobal.com/internet?step=modelselection.vm&contractId=230&countryId=36&networkId=...
Put your phone number on that link send settings on your phone install on your phone you need password and that should be last 4 digits of your phone number.
I hope it will help.
Many Thanks
Re: apn settings
I've just done that and the internet is still not connecting.
by Ace Contributor
Re: apn settings
What error you getting?
Have you turned your mobile data on?
Re: apn settings
Hi @jackwaight98,
Welcome to the EE Community.
Are you using a pay as you go or pay monthly plan?
Are you a new EE customer?
Re: apn settings
the 4G just doesnt show on the screen and ive tried checking by going on the internet but it says You are offline. MY calls and texts work, just not the internet, im on pay as you go.
Re: apn settings
Yes i am a new EE customer and I'm on pay as you go.
Re: apn settings
Hi @jackwaight98,
What response do you get if you text Balance to 150?
Re: apn settings
it says "sorry we were unable to process your request, this service is only available to EE customers" - im not sure why it says that bevause its an EE sim card that i bought from the shop.
Re: apn settings
it even says on the top left corner of my lock screen EE.
Re: apn settings
Hi @jackwaight98,
It sounds like your new SIM hasn't finished activating yet.
The process takes up to 24 hours. When did you first insert the SIM?
Have you topped it up and chosen a pack?
Re: apn settings
I bought the phone 13/07 I bought the sim and put it in the phone 20 minutes after purchasing the phone.. I then bought a top 15 minutes after putting sim in the phone. I bought a 10 pound everything pack.. I can still text and call but not getting any internet connection.
Re: apn settings
Hi @jackwright98,
Please get in touch with customer services so we can take a quick look at your account.
Re: apn settings
okay thanks. it will be my girlfriend speaking on my behalf as she's been setting up my phone as i dont know what I'm doing really haha
Re: apn settings
No problem @jackwaight98
Let us know how you get on. Smiley Happy
