by noCGN Established Contributor
add-on.ee.co.uk
Few years back I got the promo payg SIM on EE with 100GB data and quite liked that I could check my data allowance  visiting "http://add-on.ee.co.uk/" without having to log in or register for that matter.
I have purchased "EE Tablet & 4GEE WiFi SIM Only 30 days £30.00 30GB plan" and that webiste does not work.
Should the website "add-on.ee.co.uk" work for me as well, or something has changed over the few years?
I would just say, that I use the SIM in laptop so no Calls/SMS are an option for me.
Solution
Re: add-on.ee.co.uk
Hi James_B,
thank you for taking the time and replying.
I have once spoke to a few people and the first and second line of support is  .........
If anyone ever had a pleasure speaking to  A&A support who are my ISP provider knows what true support is about, my experience from EE is, that they suck.
I have done more test at home. I have insereted the SIM card into my old Samsung GT-I9195 and tried different APNs, "add-on.ee.co.uk" come on straight away. On my other laptop that has got only 3G modem "Dell Wireless | Ericsson F3607gw V2 Mobile Broadband Modul" with max supported 7.2Mbps (HSDPA), both:;
http://add-on.ee.co.uk/status
http://add-on.ee.co.uk/purchase
http://add-on.ee.co.uk/legalstuff
http://add-on.ee.co.uk/faq
http://eeebdc.prod.t-motion.co.uk/status
http://eeebdc.prod.t-motion.co.uk/purchase
http://eeebdc.prod.t-motion.co.uk/legalstuff
http://eeebdc.prod.t-motion.co.uk/faq
worked as well, and now trying it on my main laptop with the LTE module and it works as well.
I do not think that EE network is friendly with stand alone modems not supplied by EE.
So should anyone get a problem accesing add-on.ee.co.uk I recommed trying in normal phone that will trigger something on EE's network and the add-on.ee.co.uk will work for you after that 🙂
10 REPLIES 10
Re: add-on.ee.co.uk
Hello @noCGN
Thanks for coming here.
Yes this link should work for you when WiFi is turned off.
What happens when you use this http://add-on.ee.co.uk/ ?
Thanks, Leanne.
by Haydon-Berrow Established Contributor
Re: add-on.ee.co.uk
you might also check http://add-on.ee.co.uk/status
Re: add-on.ee.co.uk
Address resolve to 64:ff9b::52c0:6199 and the message is:
(I do not have any add-ons installed in my web browser)
This page isn’t working
add-on.ee.co.uk took too long to respond.
HTTP ERROR 504
Not a AAAA record for add-on.ee.co.uk or eeebdc.prod.t-motion.co.uk
and EE would not let me have a proper IPv4 address!!!!!!!!!
$ dig add-on.ee.co.uk ANY
; <<>> DiG 9.10.3-P4-Debian <<>> add-on.ee.co.uk ANY
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 18984
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 0
;; QUESTION SECTION:
;add-on.ee.co.uk.        IN    ANY
;; ANSWER SECTION:
add-on.ee.co.uk.    35    IN    CNAME    eeebdc.prod.t-motion.co.uk.
$ dig eeebdc.prod.t-motion.co.uk ANY
; <<>> DiG 9.10.3-P4-Debian <<>> eeebdc.prod.t-motion.co.uk ANY
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 7845
;eeebdc.prod.t-motion.co.uk.    IN    ANY
;; ANSWER SECTION:
eeebdc.prod.t-motion.co.uk. 81119 IN    A    82.192.97.153
Re: add-on.ee.co.uk
Hi @noCGN,
Have you tried a different web browser?
Re: add-on.ee.co.uk
Hi James_B,
Yes, both Chrome and Firefox.
Just tried console based elinks:
 <head><title>HTTP error 504</title></head>
 <body>
  <h1 align="left">HTTP error 504: Gateway Timeout</h1>
  <hr />
  <p>
  An error occurred on the server while fetching the document you
  requested. However, the server did not send back any explanation of what
  happened, so it is unknown what went wrong. Please contact the web
  server administrator about this, if you believe that this error should
  not occur since it is not a nice behaviour from the web server at all
  and indicates that there is some much deeper problem with the web server
  software.
  </p>
  <p>
  URI: <a href="http://add-on.ee.co.uk/">http://add-on.ee.co.uk/</a>                                                ...
 </p>
 <hr />
 </body>
</html>
and lynx is throwing out 504 as well
Re: add-on.ee.co.uk
Hi @noCGN,
Thanks for trying.
Please get in touch with customer services so our technical team can look into this issue for you.
Let me know how you get on.
Solution
Re: add-on.ee.co.uk
Hi James_B,
EE Employee
Re: add-on.ee.co.uk
Hi @noCGN
So are you now able to access the relevant page you need?
Many thanks,
Lee
Re: add-on.ee.co.uk
Hi Lee_H,
yes I can now access add-on.ee.co.uk | eeebdc.prod.t-motion.co.uk on my laptop with 4G/LTE modem as well.
I have marked this thread as solved.
Re: add-on.ee.co.uk
Great thanks @noCGN
Thanks for letting us know 🙂
