by WarHead
New Member
Wrong data than what I ordered.
Hey, I’ve upgraded my sim to a 100GB plan but the EE app is showing 20GB. Can anyone help, thanks.
I ordered online and then a agent rang me to complete the order and mess it up by the looks of it.
by Ace Contributor
Solution
Re: Wrong data than what I ordered.
Hi @WarHead
Welcome to the EE Community,
If you contact customer services on 150 they will be able to assist you with correcting your plan.
Thanks,
David.
by Ace Contributor
Solution
Hi @WarHead
Thanks,
David.
