by darling41 Contributor
Withings Home
I can no longer access the Live Stream CCTV using mobile data but my wife on O2 network can. Anyone else having trouble?
Solution
Re: Can't Access the Live Stream CCTV
I dunno; somewhere in the APN maybe. I only think I know the cause not the solution.
I bet O2 is still using IPv4 & so your wife's works. Look in her APN.
20 REPLIES 20
Did you once? Have you changed to EE from Orange or T-M? I believe its to do with EE using IPv6 addressing. Can you set your profile to IPv4?
  1. Yes it used to work
  2. I have been on EE from the beginning
  3. I connect through a Sky router which is supposed to be IPv6 compatible
Thanks for your interest in my problem I'll have to delve into the router setup to try your suggestion 😊
It's not the BB router; it's the EE mobile network.
So when you suggest setting my profile to IPv4 where do I do this ?
Solution
EE Employee
Hi @darling41 and welcome to the community.
What type of handset do you have as we may be able to assist.
Many thanks,
Lee
I have an iPhone 6s running the latest iOS
Sent from my iPhone
EE Employee
Hi @darling41
When accessing the cams do you use a specific manufacturer's app or a universal IP cam viewer app?
Many thanks,
Lee
I use the manufacturers app (Withings) as does my wife (she's on O2). As far as I can tell we have identical setup on our phones, she has iPhone as well.
Sent from my iPhone
EE Employee
Hi @darling41
Could you try me one thing before I get you in contact with the technical team.
Please could you turn of the 4G connectivity and go to 3G only and let me know if that helps.
Many thanks,
Lee
by muindo Investigator
I have the exact same problem on my iPhone 6s plus.
Everything was working fine until a few days ago... now I cannot access the live stream from the manufacturer's app when I am on 4g/3g.
The only way I have managed to gain access is if I am logged onto a wifi network, or if I connect to my VPN server on 4g/3g.
@muindo  But of a long shot but have you tried a network reset on the device?
Hi @Chris_B,
Once I realised this issue, I have reset and then set up the device as a completely new device.
My setup is:
Virgin Media router (in modem mode) -> netgear nighthawk r7000 (router) -> withings home (hardwired).
EE Employee
Hi @muindo
Have you been able to see if anyone else on EE is experiencing the same issue for example a friend of family member.
Many thanks,
Lee
Unfortunately not. Everyone else in the family is on O2 and can connect without a problem.
Hi @muindo and @darling41,
Have you reported this issue to the CCTV manufacturer?
Yes I have, and although they won't admit there is a problem they say they hope it will be fixed in a future update.
Hi @darling41,
Thanks for the update.
It sounds like the manufacturer have a fix on the way.
I got pretty much the same response from them, and other members of my family, on different networks, mainly Vodafone, have no issues connecting to the camera when they are on 4g.
Hopefully there is a fix soon, forced to carry on using VPN/wifi as a temporary solution.
