by Charlotte_a Investigator
Will my data will reset next month?
I've recently moved to Germany. Took out 2 contracts as told it was the best available compared to other companies.
(6gb unlimited txt & calls to uk and abroad numbers. 4g max plan)
heard others who have taken out the same contract that their data doesn't reset.
any ideas?
Solution
Re: Will my data will reset next month?
Probably not. On the 4GEE Max Plans the inclusive roaming benefits are available to UK based customers only. Your phone must be used in the UK at least once every 30 days to make calls and use mobile Internet.
Solution
