by Oggy41200 Investigator
Will a EE wifi mini work in New York
Just bought a wifi mini because we moved into a new house and was wondering if we could take it to New York and use it there
7 REPLIES 7
by Profile closed
Not applicable
Re: Will a EE wifi mini work in New York
No sorry, none of EE's dongles will work in the USA on either 4G or even 3G.  They will only work in the UK or Europe.
Unfortunately it only works on UK and Asian networks so wont work in New York or on any US network frequency. the sim will still work if you use it in your phone just the device will not work.
Have a nice trip
Thanks,
So I can just put the sim in my phone and use the 20 g of data
EE Employee
Hi @Oggy41200 and welcome to the community.
You can pop the SIM card into your phone and use as a hotspot.
Many thanks,
Lee
And it won't cost me anything extra😀
EE Employee
Hi @Oggy41200
As long as it is on one of the new 4GEE max data plans you should have no issues.
Many thanks,
Lee
by Ace Contributor
Be aware there's a 15GB a month FUP when roaming, so you can't use all 20GB abroad.
