by Wirelessman
New Member
Will A Sierra Wireless MC7354 work on EE Network?
Will A Sierra Wireless MC7354 work on EE Network?  this is a embedded device
by Star Contributor
Star Contributor
Re: Will A Sierra Wireless MC7354 work on EE Network?
The MC7354 is intended for the Americas region. It does not support 4G bands used by any network in the UK. However, 3G and 2G should work fine.
