Highlighted
by Investigator
Wifi mini
I purchased a wifi mini for my parent to use until their broadband goes in, it was bought with 6gb on it, lasted 5hours and says they have used 6gb in that time.. can this be correct???? Surely not in 5 hours??
6 REPLIES 6
Highlighted
Re: Wifi mini
Hi @Bobbipops
It depends on what they've used it for.
Highlighted
Re: Wifi mini
Morning @Bobbipops
Thanks for coming to the community 🙂
When was the device connected?
Is this on pay as you go or pay monthly?
Our How much data am I using on EE? has helpful advice to optimise data usage.
Thanks.
Highlighted
by Investigator
Re: Wifi mini
Hi.It was linked up at 3pm yesterday and by 9pm it said you have run out of data.I think that's a bit quick.ThanksSent from Samsung tablet.
Highlighted
Re: Wifi mini
Hi @Bobbipops
Is the device on pay as you go or pay monthly?
When using a WiFi device, you'll need to consider how many devices, such as phones and tablets, are connecting to it, along with what each device is using the Internet for.
Thanks.
Highlighted
by Investigator
Re: Wifi mini
Hi, Pay as go and they watched an hour of now tv and there are 2 tablets.ThanksSent from Samsung tablet.
Highlighted
Re: Wifi mini
Hi @Bobbipops
Thanks for the quick reply.
It may be worth looking at the tablets that were connected to see if they have automatic updates set to on that could have used extra data.
If you want to get this looked into further, give our Pay as you go team a call they can check the account for you 🙂
