by Lesley50 Investigator
Why won’t my iPhone 6 not connect to wi-fi but my iPad, iPod and old iPhone 5 do
Solution
Re: Why won’t my iPhone 6 not connect to wi-fi but my iPad, iPod and old iPhone
@Lesley50   Try a network reset on the device, go to settings/General/reset/reset network settings.  The device will reboot and you will need to re-enter your Wi-Fi password.  it actually sounds like you have a dodgy Wi-Fi antenna on the device which is why you lose signal when you move away from the Rueter and it only works when it’s right next to the Rueter.
16 REPLIES 16
Hi @Lesley50
Have you connected to, and entering the correct WiFi password.
What WiFi are you trying to connect to?
Hi yes I’ve tried connecting to my WiFi, I’ve had to physically place my phone on top of the hub to get internet, which is not ideal! The second I take my phone into another room (about 4 feet away ) it disconnects and goes back on to 4g again
Get Outlook for iOS
Which router do you have?
Can your phone connect OK to WiFi hotspots in cafes?
Solution
I have done everything possible, I have a sky hub, so as requested by the EE tech department, I phoned sky, they done a full speed check / diagnostic on my internet connection......everything’s working fine. I think I have been given a dodgy phone to be honest. I’ve spent 3 days trying to fix this, so I think I’ll ask for a replacement, I’m not willing to pay a monthly contract for a phone that doesn’t work
Sent from my iPad
Hi @Lesley50
Welcome to the community.
Thanks for trying everything that you have so far.
Did you try resetting the network settings, like @Chris_B suggested?
Tap Settings > General > Reset > Reset Network Settings > Follow the prompts.
Yeah done all of that, still won’t connect
Sent from my iPhone
OK, thanks @Lesley50
It'll be worth speaking to our Tech Gurus so they can run through some more troubleshooting and get to the bottom of the problem.
Please let us know how you get on.
by Ace Contributor
Might also be worth trying a new control channel on your router for the wifi. I've had issues with Apple devices before and had to manually select a different channel.
My phone won’t connect to any WiFi,  EE have contacted me and are giving me a replacement iPhone.  It looks like the aerial is faulty ☹️  I’ve only had the phone for 4 days, never mind, hopefully this one will work ok, thank you to everyone for the suggestions, it was appreciated 🙂
Thanks! You're welcome 🙂 ! Glad I could be of assistance.
@Lesley50   Happy to hear you getting a new device,  happy to help.  👍
Let us know how you get on with the new iPhone @Lesley50
Have a lovely weekend 🙂
Hi, got my new iPhone today and it’s working great! No problems with connecting to WiFi either, well impressed
Sent from my iPad
