by Ginge3
Why when I try to use my mobile data it doesn't work but yet says I have 512 mb
by Profile closed
Not applicable
Re: Why when I try to use my mobile data it doesn't work but yet says I have 512
Hello @Ginge3 sorry to hear you are having problems getting your data working. Try restarting your phone and checking this link using your phones data (not WiFi) connection:
http://add-on.ee.co.uk
Can you confirm if it works please? Also what do the data allowances show as under the status tab? 🙂
