by agdanila30 Investigator
Why my data is going so fast?
by Ace Contributor
Re: Why my data is going so fast?
Welcome back to the EE Community.
Could you tell us a bit more about what has been going on?
@agdanila30. Are you allowing apps to run in the background?
Do you watch YouTube?  If you do are you watching in HD ?
On your device it should say what apps are using what amount of data
Morning @agdanila30
If you can let us know some further information as @Peter_C @Chris_B has requested, we can help you with your data query.
Speak soon, Leanne 🙂
