by kayl-hudson21
New Member
Why isn’t my data working?
I can’t use my data at all. On any of my apps
11 REPLIES 11
Re: Why isn’t my data working?
Good Morning and welcome to the community @kayl-hudson21
What phone are you using?
Have you ensured data is switched on in your phone settings?
Are you using 4G?
Speak soon,
Katie 🙂
by Ayeza21 Investigator
Same here!!! My messages don’t send either unless it’s imessage.
Good Afternoon @Ayeza21
Welcome to the community.
Does this show as message not delivered?
Is this happening in one location?
Speak soon,
Katie 🙂
Yes the message says it’s not delivered and it happens mainly in my area but only works when I’m out of town which is rarely.
EE Community Team
Hi @Ayeza21,
Are you able to use other data applications while at home when your iMessage isn't working?
Do you have a WiFi connection at home you can try and send the messages over?
Alex 🙂
Yes, I do but when I go out I am unable to use my data which also results in me not being able to send normal text messages.
Hi @Ayeza21,
Does the Network Status Checker show any problems in your area?
Yes, I just checked and it says there are network issues.
Hi @Ayeza21,
Thanks for checking. If you register your details with the Network Status Checker we can keep you updated on the progress of the issue.
James​​​​​​​
It’s no problem but this has been going on for some time and I am unable to do majority of the basic stuff a sim is supposed to.
Hi @Ayeza21
Thanks for coming back to us.
Once the problem in the area is resolved, can you let us know how you get on with your service.
Thanks.
Leanne 🙂
