by Will10
Why isn’t my 4g working?
My 4g isn’t working most of the time not sure why as I’ve definitely not run out of data
by Star Contributor
Star Contributor
Re: Why isn’t my 4g working?
Hello and welcome to the Community.
When you say your 4G isn't working, do you mean that apps do not work as you would expect when using mobile data, such as web browsing failing?
Is the problem happening wherever you go?
Morning @Will10
If you can let us know the answers to @Peter_C questions we will see what we can do to help.
Speak soon 🙂
