by Chris_grin40
Why is my signal been poor past few days
Also calls and texting
Wigan area
by Brilliant Contributor
Re: Why is my signal been poor past few days
Have you checked the NETWORK STATUS PAGE
by Chris_grin40
How do I check the signal
Click on the network status link above and put in your post code. This will tell you if there are any issues in your area.
Morning @Chris_grin40
Have you been able to check your network on the EE Network Status Checker now?
Does this show any problems in your area?
Let us know how you are getting on 🙂
