by M-D-C Investigator
Why is my download speed approx 10Mb/s yet upload over 20?
Coverage checker states speeds should be “excellent” using Netgear 785S (with antenna).
18 REPLIES 18
Re: Why is my download speed approx 10Mb/s yet upload over 20?
Hi @M-D-C
Welcome to the community.
Could you check for any maintenance works in your area please?
It says there’s a Service problem at this postcode. A friend is experiencing the same. Frustratingly the ‘keep me posted’ gives a network error. This problem has been evident for months, we’d appreciate some priority.
Thanks for checking, @M-D-C.
I recommend speaking to our Tech Gurus for an update on what's happening.
by FesterChorizo Investigator
Mine too..what’s going on EE!
I can’t get updates either as it has a network error...
lots St in our area seem to be suffering...
FC
At which point does it come up with the error, @FesterChrorizo?
Is it as soon as you press 'keep me posted'?
Could you try on another browser or device?
Hi Chris
Its already been tried on another device ..... mine.
Are you both using mobile phones to try it, @M-D-C & @FesterChorizo?
Could you try on a desktop/laptop and let me know what happens?
by Star Contributor
Star Contributor
Where are you having these issues so I can look things up from my end?
Aynho Oxfordshire ox17 3bp
Hi Chis
I use an iPad and a windows 8 pc
Hi @M-D-C
Thanks for coming back to us.
When you select keep me posted, do you get the option to enter your email address and details?
Thanks, Leanne.
by Star Contributor
Star Contributor
You look to be possibly be in a non domninant sector position. If so, this will result in poor signal quality conditions which will hamper both the downlink and the uplink.
Much of the reason download is usually faster than upload is because there can be multiple downlink streams compared to only one uplink. However, if a device finds itself in poor conditions, it will use a single stream for downlink (in diversity). As the downlink side is usually more loaded, it is for this reason that download and upload can end up appearing the wrong way round.
However, without access to EE's internal tools, I can't comment about any site faults themselves.
Hi Leanne
yes I do. I choose text.
Thanks for coming back to the community @M-D-C
You will get updates for the area by text in this case.
If you would like this looked into further get in touch with or Tech Care Team, who will be able to help you further.
Thanks. Leanne.
It’s still mega slow, when is this going to be fixed?
EE Community Team
Morning @FesterChorizo,
Have you had any updates after @Leanne_T registered your mobile number for texts?
You can call your technical gurus for further information on the outage.
Alex
No, no updates...just slower (half usual speed) of downloads.....still
F
I would recommend following the advice from @Alex_S and contacting our technical gurus for further information.
Let me know if you have any further questions in the meantime,
Katie 🙂
