by molly_mae Investigator
Why doesn't my 4G allow me to use snap chat?
My 4G allows me to use all other apps however it does not work with snapchat. In settings, mobile data is turned on for snapchat but still does not work. I have tried everything but nothing seems to work.It has nearly been two weeks.
It is not snapchats system as it works on wifi and peoples hot spot.
I would appreciate some help and advise please.
11 REPLIES 11
Re: Why doesn't my 4G allow me to use snap chat?
@molly_mae  Have you tried login out if Snapchat and deleting the app then turn off the device give it about 30 seconds then restart the device and reinstall Snapchat and log back in and see if it works.
EE Employee
Hi @molly_mae and welcome to the community.
Has the above information helped at all?
Many thanks,
Lee
Thank you for the help but it still won’t work. 😞
I’m afraid it still doesn’t work.
EE Employee
Hi @molly_mae
Is Snapchat the only app you are having an issue with?
Many thanks,
Lee
Yes however it works on WiFi and people’s personal hot spot.
Thanks for helping to find a solution.
EE Employee
Hi @molly_mae
Does changing your signal down to 3G help at all?
Many thanks,
Lee
I have just gave it a try and unfortunately it still does not work. I think I will back up my phone and reset it all together. Hopefully that will work.
Many thanks.
EE Employee
Let us know how you get on @molly_mae
Many thanks,
Lee
by Katerenniexox
New Member
Im with ee and mine started off with me not being able to use my 4g for snapchat then it stopped workingn for instagram and it has carried out on other apps and safari, youtube and email are the only ones that i am aware work on 4g. I have 20g and i am sure I haven’t ran out or anything like that. This also happend to 2 of my close friends
Hi @Katerenniexox,
Thanks for joining the EE Community.
Have you checked your content lock settings in My EE?
