by Catherine27 Investigator
Why does my phone not work when I have 3G or 4G?
Solution
Re: Why does my phone not work when I have 3G or 4G?
Read more
@Catherine27   On the device go to Settings>General> scroll down and look for PROFILE if it's there delete it.
8 REPLIES 8
by georgereading Established Contributor
hi @Catherine27 any more info about your phone,area where you are? Also check on the network status about any ongoing upgrade works?
Thanks 4 the reply; my I phone 5s works perfectly well when I have wifi but just not when I'm out and about having 3G or 4G.
Sent from my iPhone
Sent from my iPhone
@Catherine27   On the device go to Settings>General>Reset>Reset Network Settings.
This will do exactly what it says, it is network refresh but it will also wipe your Wi-Fi passwords, nothing else will be wiped on the device,  So you will need to re-enter you wifi passwords after do this.
 On a side note what do you mean doesn't work when you have 3G/4G when outside do you mean you can't make calls or send taxes or none of your apps work unless on Wi-Fi?
 Have you allowed your apps to use cellular data if that is your issue ?  It's under Settings>Mobile Data.   Scroll down and any toggle that is highlighting a green background is enabled  to use cellular data.
Hi. Thank you 4 the reply. I've already done that twice that's why I'm really confused.
Sent from my iPhone
Sent from my iPhone
  • Are you pay monthly or PAYG?
  • Where did you purchase your iPhone and how long have you owned it.
Hi thank u for replying I've had my iPhone 5s a while, but I moved from Vodafone to EE in November and it's been since then that it hasn't worked properly.
Sent from my iPhone
Solution
Read more
Hi thank u so much for your reply. I have been and deleted so hopefully it will work now, thank u ever so much.
Sent from my iPhone
Sent from my iPhone
Recent solutions
