by Didi1
Why does my data usage go from 80% used to 100% in 1 hour?
Re: Why does my data usage go from 80% used to 100% in 1 hour?
You have used 20% that's why.
Only you know what you are doing, or you can check your phones data app to establish what is using data.
Hi @Didi1
Thank you for becoming part of community 🙂
I can see @Northerner has offered support with this and I'd also recommend taking a look at our How much Internet data are you using on EE? support article for some guidance.
Cheers
Richard
