by HWaine
Why does my EE mobile WiFi work in uk but not in spain
Re: Why does my EE mobile WiFi work in uk but not in spain
If you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150?
Often just rebooting the device is the simple remedy. Otherwise try logging into your MyEE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
PAYG is auto enabled for roaming. You don't need to & can't do any of the above.
by HWaine
Thanks for the info, it’s a pay as you go sim in a small WiFi device, I
spoke to EE before we left to check and it worked in the airport but since
arriving there is a problem connecting it to the internet!
Hi @HWaine.
Welcome to the community.
Does the device have a signal?
Are you able to log into the admin page and select a different network?
Jon
