by Mad-at-EEK
Why do I never get a proper signal indoors or outdoors? Why am I still with EE?
Hi, can someone please tell me why I never have more than 3 bars indoors or outdoors. The EE signal is pathetic! Not sure why I am still with them!?
Re: Why do I never get a proper signal indoors or outdoors? Why am I still with
Good Afternoon @Mad-at-EEK
How long has this been happening for?
When you enter your post code in our Network Status Checker what does this report?
Speak soon,
Katie 🙂
by Mad-at-EEK
Katie B, hi
Thank you for your email.
I have never received 4 bars leave alone the full Monty. It always moves between 1 - 3 bars.
The status tracker says no engineering works are taking place, but the bars don't rise above 3. Even now, it is between 1 - 2.
Please help
Many thanks
by Brilliant Contributor
3 bars is not bad.
But they are only a visual representation.
What are your speeds like?
