by Klb22 Investigator
Why can’t my phone connect the internet without WiFi, My mobile data is on?
8 REPLIES 8
Re: Why can’t my phone connect the internet without WiFi, My mobile data is on?
Where are you? Doesn't that aeroplane symbol indicate you are either roaming or in flight mode?
I am in the UK, I believe the symbol is location services?!
Hi @Klb22
  • Check you have 4G/LTE active under settings.
  • Reset your network settings
  • Check your local network for issues here
Are you in an EE 4G area?
Sorry to seem thick but how to I check I have 4G/LTE active? And also reset network settings? My area has no issues, I checked the status on here. Thank you
@Klb22  Cellular data might be on but have you allowed the apps to use cellular data ?
To reset your network settings go to
Settings>General>Reset>Reset Network Setting.
 Your device will reset and you’ll need to put your WiFi password last back on the device after this.   You’ll not delete anything from your device doing this.
Hello Chris,
Yes i I believe I have them activated as they are green as shown?
I have just reset my network settings, it then let me acces the internet for a few minutes before then coming up with the same message again. So it temporarily helped.
Good Morning @Klb22
Everything does look to be active, have you had the chance to give us a call?
Our technical support team will be able to look at this in further detail.
Keep us updated on how you get on,
Katie 🙂
Recent solutions
