by Sarni969 Investigator
Why can’t I use Facebook & Messenger without WiFi. I phone 6 plus
For the last couple of months, whenever I try to go on Facebook and Messenger without wi-fi, it comes up no internet connection, please retry. All other apps work fine apart from these 2. Mobile Data is turned on in settings. I’ve deleted apps and reinstalled, but still dosn’t work. So annoying
15 REPLIES 15
Facebook not working unless connected to Wi Fi I phone 6 +. All other apps work
by Star Contributor
Star Contributor
Re: Facebook not working unless connected to Wi Fi I phone 6 +. All other apps w
Hello and welcome to the community.
When you go into Settings--> Facebook  is Mobile Data siwtched on?
Yes it is 🤨
Sorry meant to do a 😁
by Star Contributor
Star Contributor
That's rather odd then with other apps working fine. Hopefully another member of the community will see this soon and have other suggestions.
Re: Why can’t I use Facebook & Messenger without WiFi. I phone 6 plus
Hi @Sarni969
What tariff are you on?
Have you tried resetting your network settings? (Go to Settings>General>Reset>Reset Network Settings. )
Thanks,
Hi @Sarni969,
Welcome to the EE Community. Smiley Happy
Have you tried deleting and reinstalling the app?
Yes, deleted loads of times, didn’t make a difference 😔
Hi
Yep, every other app works fine. Can’t work it out 🤔
Morning @Sarni969
Thanks for coming back to us.
Is your iPhone software up to date?
To check go into Settings > General > Software Update.
Speak soon, Leanne 🙂
Hi Leanne.
Yes, always update my software.
Thanks for coming back to me @Sarni969
If all other apps work, I would suggest giving us a call so we can look into this further for you.
Let us know how you get on.
Thanks, Leanne.
Thanks Leanne
Recent solutions
