by Debk Investigator
Why can’t I receive emails when on 4g
8 REPLIES 8
Re: Why can’t I receive emails when on 4g
Hi @Debk
Have you set your email client up correctly?
by Skilled Contributor
Skilled Contributor
What type of device are you using?
Sorry iPhone 7+
Sent from my iPhone
Yes
Sent from my iPhone
Hi there @Debk
Thanks for coming here 🙂
Do you get an error message when you try and download your emails?
Who is your email provider?
Leanne 🙂
Skilled Contributor
Check under Settings > Mobile Data
If you scroll down to your applications, you should see data switches individually. Check that mobile data is turned on for mail.
If this is turned on, you can send yourself e-mail settings via the following link - http://setup-ee.wdsglobal.com/
Thank you everyone!! I’ve (you’ve) solved it 🤗
Glad you got this sorted @Debk
Have a lovely weekend 🙂
