by debbieelaine
Why can't I get my home cctv on my samsung A3 when I'm out of my WiFi range
I've had the dvr set up for remote access and it works fine on other devices but not the A3 or S5.
7 REPLIES 7
Re: Why can't I get my home cctv on my samsung A3 when I'm out of my WiFi range
Does the CCTV connect via an app or via Web browser to your phone?
by debbieelaine
I had to download ivms4500 to access the cameras
@debbieelaine: What network is the CCTV on?
According to the app reviews on the play store your issue is common. You may need to contact the manufacturer or read their support page as your issue doesn't look like it's EE network related.
by debbieelaine
My home network is sky broadband and my mobile network is ee
by debbieelaine
Ok, I'll try that.
Thank you for your help
Hi @debbieelaine
Thanks for coming to see us in community 🙂
Please do come back and share the solution with the community, as the answer or hints and tips could really help others.
Thank you
Richard
