by mawallace Contributor
Which phones can use the 4g 800 frequency
 I am changing my phone and want one that will be able to use the 4g 800 frequency that they turned on last year.
I've looked at their website and can't find out which phones can use this frequency. Any ideas appreciated
by Ace Contributor
Solution
Re: Which phones can use the 4g 800 frequency
Please click here for list EE [ 4G Calling ] phone that work on 800MHZ so you can choose one of in them.
Many Thanks
by Ace Contributor
Solution
Many Thanks
@mawallace are you in a 800Mhz area?  As not all mast put out this frequently.
I think so bit how do I find out
EE Employee
Good Morning @mawallace
You can check your coverage on the Coverage Checker but this will only show 2G, 3G, 4G not the frequencies.
You can also input your device choice in the box below the postcode and this will show what you'll get with that particular phone.
Hope that helps!
Thanks - Karen. Smiley Happy
