by Redken Investigator
Where has my data been used ?
How can I find out where my data has been used ?
Solution
Re: Where has my data been used ?
Good morning @Redken
Thanks for dropping by the community. 🙂
Did the great advice from @tahirmian answer your question?
Please let me know if you need some more help.
by Ace Contributor
HI,
@Redken
Please check this How to See Which Apps Are Gobbling Up the Most Mobile Data on Your iPhone
And for android phone go in settings then data useage where you can check which app is using more data.
Solution
Problem solved .Thank you .
Regards
Redken
Fantastic, that's what I like to see @Redken
Thanks for letting us know. 🙂
I hope to see you around the community again soon.
Chris 🙂
Recent solutions
