by waveyx Investigator
When I joined EE I could use WhatsApp and Facebook messenger now I can't, why?
When I first joined EE I used to be able to use WhatsApp and Facebook messenger using 4G, now I can't connect to either of these unless I'm connected via wifi, why is this?
i haven't changed anything on my phone and I still can't connect to these apps when I have maximum signal. Friends on other networks have no issues, even with weak signals. Is it just me or is it the network?
Not happy!
Solution
Re: When I joined EE I could use WhatsApp and Facebook messenger now I can't, wh
@waveyx In Settings>Mobile  Data when your scroll down are these app allowed to use cellular data ?  The toggle should show green.
9 REPLIES 9
EE Employee
Good Afternoon @waveyx
Welcome to the Community! Smiley Happy
Sorry to hear you're having issues with some Apps.
Have you tried deleting a re-downloading the Apps?
Also can you access the internet OK on your device?
Many Thanks!
Karen. Smiley Happy​​​​​​​
Can access the internet just fine. Facebook and loads of other apps work just fine, just seem to have issues with those apps?
Cheers
Dave
Hi @waveyx,
Have you tried deleting and re-installing the Apps as suggested by @Karen_C?
Done, WhatsApp still won't work without wifi!
Cheers
Dave
Hi @waveyx,
What happens when you try to send a message via WhatsApp?
Do you get a particular error message?
What type of phone are you using?
When I open WhatsApp it tries logging in the I get a message saying it can't find a network and to connect via wifi.
Using iPhone 6s
Cheers
Dave
Solution
Chris_B,
thanks. That worked a treat, just wish you'd been the first solution, would have saved a lot of hassle 😁
@waveyx  I did see your post yesterday just after you posted it but I didn't have time to reply (sorry).   Got there in the end though.  Smiley Happy
Recent solutions
